I have a water dispenser that has not been working for the last few days. Today i replaced the water valve assembly ( part # wr57x10032). The unit still does not work. I disconnected the blue connector behind the toe kick. I have water up until this point but still no water form this point to the door dispenser. Any help would be greatly appreciated. The temperature in the freezer is 34 degrees.
Thanks and have a great day:)
can anyone help with my problem? thanks
Did you every resolve this. I'm having the same Exact Issue.
