My son /daughter-in-law, have a washing machine that appears to work fine as far as the control system. But, the agitator and drum seem to stop to abruptly when the lid is raised. It recently would not turn and burned the belt some what. I investigated for them, it was set for a small load and still had water in the tub. I set it for spin and it started right up but I noticed when I raised the lid that the tub came to an abrupt stop after about a turn. Our washing machine basically coasts to a stop. What could be the cause for this?
Originally Posted by: brmoon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My son /daughter-in-law, have a washing machine that appears to work fine as far as the control system. But, the agitator and drum seem to stop to abruptly when the lid is raised. It recently would not turn and burned the belt some what. I investigated for them, it was set for a small load and still had water in the tub. I set it for spin and it started right up but I noticed when I raised the lid that the tub came to an abrupt stop after about a turn. Our washing machine basically coasts to a stop. What could be the cause for this? Br, Is the model number you supplied, for your son's machine ? If that's the case, You want to start at the brake rotor / stator and thrust bearing assembly, Part number: AP4373023
Part number: AP4045273
Part number: AP4009132
Part number: AP4024823
The model number you gave, indicates that this unit is an older Admiral built product, and all these parts are most likely well worn, and out of adjustment, and need to be replaced. It's an involved repair, but somewhat easy, with basic tools, and a couple of longer screws, to dismantle the brake/rotor assembly safely. We'll be happy to assist, when you're ready to start the repair. :) :) :)
Using the model # given, it comes up as a Maytag washer, not a Whirlpool.
It is my son's machine. I do believe you are correct that it is an older Maytag. They recently were married and were as most newlyweds having to pinch pennies. Overall the machine appears to be in great condition. Thanks for the quick responses.
I noticed that there are two possible transmissions for this washer. How do I determine which parts list to order from? Will this be a part of the serial number?
Originally Posted by: brmoon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I noticed that there are two possible transmissions for this washer. How do I determine which parts list to order from? Will this be a part of the serial number? BR, The first two numbers of the serial number, is the "series" number for orderring parts. In the APP parts diagram, you will see the two parts break down diagrams. Series 15, if the first two numbers are 15 or lower, you use and order parts from the series 15 diagram. Series 16, if the first two numbers are 16 or above, you use and order parts from the series 16 diagram. Most of the parts you need will most likely substitute over to the series 16 machine, anyway. At this point, I don't see you needing a transmission, it's a possibility, but not likely, based on the information in your first post. :) :) :)
Thank you very much. I am sure they will feel a little relief. The transmission is quite costly.
Originally Posted by: brmoon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you very much. I am sure they will feel a little relief. The transmission is quite costly. BR, If I thought you or they had a bad transmission, they'd be better off buying another unit. There's still a 10 % possibility, there may be a transmission problem. I'm pretty sure, once you get the parts I reccomended installed and adjusted, they'll be fine. That model number indicates that that unit was produced at the Admiral Laundry Plant(Admiral was a Maytag subsidiary)in Searcy, AR. Technicians, used to refer to those units as a "Searcy platform/built unit". It was a pretty decent unit, the most common failure was/is the thrust bearing assembly, and if you let it go long enough, eventually the brake rotor would fail,as well. Good Luck, :) :) :)
I would tilt the washer back and remove the single belt. Check the motor and pump to verify they are not hard to turn. Turn the tranny pulley, one direction spin, the other agitate. If hard to turn in spin, you probably have a bad brake in the brake housing.
