The light bulb and the control lights for the fridge and the freezer all went out at the same time. I can replace the bulb if it's bad but what about the temp control lights? I tried replacing all 3 light bulbs in the fridge side of the unit and when screwing in the last bulb the fridge and freezer temp lights go out on the control unit?
#19 controls the frig could be a failure in that v2k04 attached the following image(s):
I tried replacing all 3 light bulbs and when I try as soon as I screw one of the bulbs in all of the way the lights on the temp settings for the fridge and freezer go out. What do you think?
