Works good but makes screeching sound. Think it is the wheel which the drum rests on. I have made this type of repair on previous dryer. My problem - can't figure out how to remove the drum to get to the part needing replacement. Have removed the top and the front but that is as far as I can get. the back is solid as is the bottom - can't get to the belt to remove it so that I can remove the drum. Please helpppppppppp.
The screeching is caused by metal to metal on the front portion of the dryer. Replace the slides: SublimeMasterJW attached the following image(s):
