aww
#1 Posted : Sunday, November 28, 2010 6:32:37 PM(UTC)
aww
I just brought a dryer out of my basement where it had been stored. The dryer spins but it does not heat. It was nearly new when I got it but when I brought it up from the basement into the laundry room it doesn't heat. How do I replace the fuse? What else should I look at before I buy a new dryer?
Thank you. AWW
#2 Posted : Monday, November 29, 2010 12:58:49 AM(UTC)
I cannot find any info on the given model number, please check it.
Sounds like you have not started troubleshooting so there are a number of things that can cause your problem.
First check the power to the unit.
The heating coil requires the full 240 volts while the motor etc, can run on half the line 120 volts.
Next check the heating coil and the thermal fuse.
Perhaps the following will be helpful
http://www.applianceaid.com/dryers.html
