Can anyone help me with the wiring from the ovens that plug into the ERC board. Its an original board and I'm just trying to reconnect them because I think I wrote down my connections wrong before I disconnected them. I need help with the black wire from the J5 connector that has 3 other looped terminal connections. I also have a grey with that I think plugs into the L1-1 terminal or the MDL1 terminal, and a black wire with a white stripe that I think plugs into the MDL2
Thanks,
Fred
I believe the grey wire goes to the MDL1 terminal and the black/white wire goes to the MDL2. The black wire usually is the hot line. There is suppose to be a tech sheets with the wiring diagram inside the control panel compartment.
