acostafam
#1 Posted : Wednesday, November 12, 2008 6:29:37 PM(UTC)
acostafam
The right front burner often does not light by itself. It lights sometimes. It has gas and can be lit with a match or butane lighter. I have replaced the ignitor on that burner, but it still does not light by itself on a regular basis. When I turn it to the ignite mode the other three burners will spark very clearly, but not always the right front. Does this need a new ignition module, or a new valve?:confused:
#2 Posted : Wednesday, November 12, 2008 7:19:08 PM(UTC)
Most likely the problem is a bad spark module (ignition module). It is located under the top panel.
- The part number for the spark module is AP174421
Here are the break down diagrams for the Amana range Model ARG7800E
