Dawgpound20004
#1 Posted : Wednesday, November 12, 2008 4:28:05 PM(UTC)
Dawgpound20004
ok first off my washer was working fine then the timer went bad so i replaced it and now it wont spin at all so i was told it was prolly just the lid switch so i replaced it and it still wont spin i dont know much about washers so i could use some help thank you
#2 Posted : Wednesday, November 12, 2008 6:51:15 PM(UTC)
Does the motor run on spin? Does it drain? Does it make any unusual noise?
Here are the break down diagrams for the Roper washer Model RAX4232PQ0
Dawgpound20004
#3 Posted : Thursday, November 13, 2008 3:55:52 AM(UTC)
Dawgpound20004
it agaitates and everything else just fine and i tryed the spin cycle without clothes in it and the agaitor was spinning but when i tryed it with clothes it wouldnt do anything
#4 Posted : Thursday, November 13, 2008 10:10:57 AM(UTC)
If it was agitating during the spin then the transmission is bad and has to be replaced.
- The part number for the transmission (aka a gear case) is AP3096209
