My Amana gas dryer is making a loud scratching noise as it spins and is slightly off kilter as small items are often found hanging when I open the door and some of my whites now have small grease marks after a time in their.
It gets the job done (the heat works, all the buttons work) but it is loud and potentially damaging to the clothes.
Any thoughts?
Please advise.
Thank you.
Remove the front panel and the drum. Check the glides and the front drum seal (#11 & #3 on the diagram). - The glide (have to order two) Part number: AP4046795
