After I used the self cleaning mode on my kenmore electric oven a F1 error message showed up with the fan running continuously. We have shut off the breaker for 24 hours, unplugged appliance, pulled the oven out and unhooked the fan but nothing seems to stop the error code from coming back. Now the oven will not even come on, it has stopped working too! Your help will be greatly appreciated!!!:confused: :confused: :confused:
Most likely the problem is a bad control board (aka a clock). Possible the oven temperature sensor can be bad too but the clock should be replaced first. - The part number for the clock is AP2667336 Gene.
