PeteC
#1 Posted : Tuesday, November 11, 2008 8:44:58 AM(UTC)
PeteC
The oven will not self clean. The door does not appear to lock when the door lock lever is moved to the full right position?
#2 Posted : Tuesday, November 11, 2008 6:38:20 PM(UTC)
Possible the latch lever is bend or the latch itself is broken.
Here are the break down diagrams for the Jenn Air range Model S160
Whirlpool slams door lock on/off during baking, then cooling (Oven Repair (including Ranges and Cooktops))
by 34Ford 9/29/2022 3:27:58 PM(UTC)
GE WCVH6800J0MS door lock DIY repair? (Washer Repair)
by TimBlock 4/10/2022 3:53:57 PM(UTC)
Washer showing voltage on all three door lock leads (Washer Repair)
by metalman33 11/6/2021 11:49:11 AM(UTC)
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Oven fan won’t stop/door locked/ F3 error (Oven Repair (including Ranges and Cooktops))
by Lizete 10/9/2020 7:53:38 AM(UTC)
Maytag Neptune (Front Loading) Washer Door Locked (Washer Repair)
by frjosephklee 5/4/2020 9:03:35 AM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
maytag mgs5752bds gas range door lock (Oven Repair (including Ranges and Cooktops))
by bmcd47 12/19/2018 7:33:43 AM(UTC)
whirlpool front load won't run door locked won't open. (Washer Repair)
by bob67 12/6/2018 3:54:59 PM(UTC)
electronic door lock not activating (Washer Repair)
by cleetuor 10/27/2018 7:47:25 AM(UTC)
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 1/19/2018 1:24:46 PM(UTC)
Oven door lock (Oven Repair (including Ranges and Cooktops))
by von.ahouse@hotmail.com 10/29/2017 8:46:57 AM(UTC)
Replacement Door Lock Wiring (Washer Repair)
by cjohns62 7/27/2017 10:06:28 AM(UTC)
Whirlpool Accubake Double Oven Lower Oven Door Locked (Oven Repair (including Ranges and Cooktops))
by Malexi 6/2/2017 9:46:25 AM(UTC)
