Originally Posted by: bilrud  Pilot Light Is On, But Nothing Happens When I Turn Oven On No Noise No Gas Comes Out Burner ? Its A Old Built In Oven Bil, I can't get any technical or parts information, with the model number you supplied. Could you please try again, the serial and model plate is usually, attached to the front frame , when you open the oven doors, it could also be under the removable oven bottom panel, if it's that old. But, based on your info, You most likely have a bad bake burner valve and/or thermocouple, since you have a pilot . Thanks, :) :) :)
