andynh
#1 Posted : Tuesday, November 23, 2010 11:15:06 AM(UTC)
andynh
Hi all,
Thanks to all the posts here, I have successfully pulled the front panel and drum to access the broken belt on our DE412. Found the belt diagrams, too....excellent! Bit of a stupid question, but where does the belt fit on the actual drum itself? There is a groove, but there is also a black "wear" mark inside of the groove. The band was totally off the drum, so I couldn't tell. Common sense would put it in the groove, but that black wear line tells me otherwise???
Thanks! Andy
magician59
#2 Posted : Tuesday, November 23, 2010 11:46:10 AM(UTC)
magician59
Place the belt right over the line.
