chkaotic
#1 Posted : Monday, November 10, 2008 6:43:11 PM(UTC)
chkaotic
Earlier today, my dryer just stopped working after changing loads. I checked all the power going to the dryer itself, and it is all fine. I also checked the thermal fuse, but the dryer still wouldn't power on at all. Even the control panel doesn't seem to be recieving any power. Anything else that you guys might suggest troubleshooting before I spend way to much to get a repair man out here? Any help would be greatly appreciated. Thank you.
libertyappl
#2 Posted : Tuesday, November 11, 2008 8:16:48 AM(UTC)
libertyappl
Open the unit and check for a broken wire.
Nat
tfam4
#3 Posted : Tuesday, November 11, 2008 8:24:04 AM(UTC)
tfam4
when u say u checked the thermal fuse ? is that the plug in at the wall ?? if so there is another fuse in the back panal of the dryer u will have to take the cover off to find it . i am just asking . for i had done it 2 times before myself good luck
chkaotic
#4 Posted : Tuesday, November 11, 2008 1:05:46 PM(UTC)
chkaotic
When I speak of the thermal fuse, I mean the one inside the unit itself. As for the wires, they all appear to be intact.
#5 Posted : Tuesday, November 11, 2008 2:03:33 PM(UTC)
Could not find a wiring diagram for this unit so take the below as guesses
Looks like the machine has a belt break switch, you may have a broken belt.
Check the door switch
libertyappl
#6 Posted : Wednesday, November 12, 2008 6:33:28 AM(UTC)
libertyappl
We had one resently that was doing the same thing and traced it down to a loose wire in the wire harness at the motor plug.
Nat
