The temp of the fridge varies by 10 - 15 degrees indepdent of the outside temperature. I am thinking the thermostat needs replacing but the only part in the list is a defrost thermostat. what else could it be other than old age and my limited skill?
Is the freezer part staying cold?
Nat
Sounds like you may have do do some more troubleshooting. But if you do decide it is the thermostat look at Model RT19F5DX3AItem 21 in the 4 Shelves & Support section Part Number AP2146546 |
THIS FORUM IS DEAD!!!!!!! |
