Kyle
#1 Posted : Monday, November 10, 2008 1:51:58 PM(UTC)
Kyle
My upright freezer works fine for a week or so, but then it gets warm and food starts to soften as water is coming out the bottom. Then after about 2 days, it will chill up again and food gets frozen again.
It seems to me that the freezer is staying in defrost mode too long. Would this indicate a bad defrost timer? or something else?
thanks for any suggestions
Kyle
libertyappl
#2 Posted : Tuesday, November 11, 2008 8:23:49 AM(UTC)
libertyappl
Most likely the defrost timer and a clogged defrost drain(water coming out the bottom)
Nat
