Samsung microwave cabinet installed in RV.
We found LCD with multiple displays showing but not flashing.
"pressing" control panel choices doesn't do anything; accept twice able to get "6" to show on display which also started microwave.
Light inside works fine. Unit approx 4 years old.
Most likely the problem is a bad touch pad. Unfortunately there are no on-line information about Samsung microwaves available.
Originally Posted by: Gene  Most likely the problem is a bad touch pad. Unfortunately there are no on-line information about Samsung microwaves available.
Gene. Thanks Gene Is this something an individual can replace? If not, is this something that is costly to have replaced? Seeing as microwaves can be had for $70?
William
THANKS -- Microwave has been sitting unplugged since we brought it home from camper last week. I plugged it in. Voila! Maybe it got damp????? who knows? But it works! Thanks again, Rev. Larry Watson aka ridinpreacher.
