ratra
#1 Posted : Sunday, November 9, 2008 11:51:39 AM(UTC)
ratra
Hi GUYS:
I am triying to find the following G.E. Cooktop parts
1- WB17X5109- Harness & Conn 4 pin LH
1- WB17X5110- Harness & conn 4 pin RH
I cant replaced with other parts because this 4 pin block is a sealed block.
Please help me with this problem. Some of the terminal inside the block are burned. The top module is new.
sincerely
Ratra.:mad:
libertyappl
#2 Posted : Monday, November 10, 2008 5:09:28 AM(UTC)
libertyappl
These are the closest to yor model number I could find (Model JP362B9N1 & Model JP362B9K1) and they both show a 5 pin terminal block.
Hope this will help you a little bit.
Nat
