Hi, We received a new Electronic Oven Control Assemby from your company. Because the light went out. After putting in the ribbon and plug ins installed lock to lock. I must have done something wrong because all that works is the oven light which I cannot turn off and the clock that blinks and the rest of the oven doesn't seem to work . need help???
Thank you gary
Remove the schematic you will find behind the door and check for a module wiring mistake.
