Scotsman DCE33PA-1WB. I found an open link in a part. Unfortunately I don't have a manual & can't seem to find one to tell you the name of it for ordering purposes. Regardless, it is in front behind lowest panel w/ a clear 3 prong connector red & black wire attached to it along w/ a 1/4" water hose next to similar looking object w/ red 3 prong connector w/ red & black wire attached (It tests good). Part attached to clear prong is open link. Also part w/ long white stem w/ slot & screw fell apart while unhooking wires to test. Obviously needs replacing now, but tested good even after falling apart. It is pumping & spraying water. Drain pump is working fine. Temp inside ice machine is 56 degrees w/ 72 degree Florida spring water pumping through it. I hear what I suspect is the fan motor running smoothly & quietly. Any help would be appreciated. BTW, you know how things happen in 3's. Well this happened a coupla weeks back, & I put it on the back burner. Then the dryer, today the washer (water inlet valve & fixed.) OY! Thank you!
