robstuff
#1 Posted : Thursday, November 18, 2010 2:19:39 PM(UTC)
robstuff
I have no heat coming from my Furnace. I have 4 flashed indicating an Open High Limit switch. I replaced the switch and the burners came on briefly but the flame never kicked on. What else can cause the four flashes besides the limit switch being open?
FYI I had a similar situation last Spring when I got 4 flashes. I replaced the limit switch at that time and it seemed to solve the problem for the rest of the season.
Thanks in advance for your help.
Poodle Head Mikey
#2 Posted : Thursday, November 18, 2010 2:55:49 PM(UTC)
Poodle Head Mikey
Check the wiring diagram and see if maybe there is more than one limit in that circuit.
robstuff
#3 Posted : Thursday, November 18, 2010 3:30:24 PM(UTC)
robstuff
Only one limit switch, so that's not the problem.
Could it be the flame rollout switches? Can these be reset?
Poodle Head Mikey
#4 Posted : Thursday, November 18, 2010 3:32:12 PM(UTC)
Poodle Head Mikey
Do they have a small button to push? Right betwen the wiring terminals?
whsydddy9
#5 Posted : Sunday, November 21, 2010 7:16:55 AM(UTC)
whsydddy9
There is obviously more of a problem if this high limit has to be replaced annually. Roll out which trips this limit is a sign of greater problems that could be FAMILY SAFETY problems. GET AN HVAC CONTRACTOR FOR A CURE.
