jennyparadox
#1 Posted : Friday, November 7, 2008 1:02:30 PM(UTC)
jennyparadox
The washer's timer won't advance making the machine not advance through the cycles. It works if we manually turn the timer and put it on the next cycle. It does not make any noises and each cycle seems to work how it's supposed to. I do have the owner's manual and tried the troubleshooting guide but got no results. If we don't turn the timer, each cycle continues to go until we do turn it except for the last part of the rinse cycle, which, shuts off after refilling.
libertyappl
#2 Posted : Friday, November 7, 2008 1:25:46 PM(UTC)
libertyappl
Sounds like the timer needs replaced. Part number is AP3100187.
Nat
jennyparadox
#3 Posted : Friday, November 7, 2008 1:33:12 PM(UTC)
jennyparadox
Do you think just the timer or the whole timer with motor?
libertyappl
#4 Posted : Friday, November 7, 2008 1:50:46 PM(UTC)
libertyappl
The part number I gave you above is the timer w/timer motor.
Nat
