bubbae
#1 Posted : Tuesday, November 16, 2010 4:46:58 PM(UTC)
bubbae
We installed this used dishwasher a couple of weeks ago and it worked ok for a few times, then one day it finished its cycle and the readout stayed on 'CL' even after opening and closing the front, trying to run diagnostics, power on/off, etc. So, at this point, it wont do anything. If you turn it on all you get is 'CL' and I cant figure out how to clear it out so that I can run diagnostics or just run a wash load. Before I installed it I ran diagnostics and the heater was bad, so I know that is an issue, but I dont see how that would leave the washer in 'CL' mode. The other possibility is that there is some kind of clog in the line (the guys who put it in had to clean some crud out of the sink disposal). Also, are there any issues with water/vacuum locks on the drain lines of these things? I am not sure really how to proceed other than just start tearing things apart until I find something.
Anyone have any ideas? Would much appreciate it!
-Chris
