The dispenser does not hold the rinse agent. I'm not certain if only the gasket needs to be replaced, or the entire dispenser. Either way, how do I remove the old dispenser. I see no screws to disassemble the dispenser from the door. I did find the replacement parts, either the gasket or the dispenser.
Hi Josefa,
Did you notice where it's leaking from exactly?
