McGuyVr
#1 Posted : Tuesday, November 16, 2010 5:49:14 AM(UTC)
McGuyVr
The fine filter assembly has a tub the allows water to flow down but the tube is always getting plugged with debris. I am guessing that some pump or grinder is not working correctly or has stopped working. What can I check or replace to allow things to flow again? Thanks for any help.
Joe / APP Team
#2 Posted : Tuesday, November 16, 2010 8:08:27 AM(UTC)
Joe / APP Team
Mcguyvr,
First things first,
Have you removed the sump cover and sump filter and checked and cleaned them out ?
Part number: AP3186583
Part number: AP3794336
Is your water temperature hot enough(should be 120 dgrs minimum in the tub on the first fill) ?
Are you sure you don't have a drain problem in the disposal or sink drain system ?
You could have a damaged maserator inside the pump impeller assembly, but I would not start there, until the other reccomendations have been checked and varified.
Good Luck,
:cool: :cool: :cool:
McGuyVr
#3 Posted : Wednesday, November 17, 2010 4:45:13 PM(UTC)
McGuyVr
Thanks for the information.
I took apart and cleaned Part number: AP3794336 which was clogged. I am hoping that i dont need to replace the pump drain. I will keep an eye on it. Thanks again.
Joe / APP Team
#4 Posted : Thursday, November 18, 2010 5:40:40 AM(UTC)
Joe / APP Team
Mcguyvr,
Great, I think you'll be fine from here on out.
Just get yourself a schedule to clean out that filter.
