loggergirl
#1 Posted : Monday, November 15, 2010 1:35:58 PM(UTC)
loggergirl
My Frigidaire side by side refrigerator portion is freezing the contents. Please help. It doesn't matter which setting the Frig & Freezer are set on.
#2 Posted : Tuesday, November 16, 2010 3:42:10 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for FRIGIDAIRE PLHS269ZDB3 Frigidaire/refrigerator | AppliancePartsPros.com
Since the cooling in the fresh food side depends on freezer temperature it is not a bad idea to measure the freezer temperature. Should be close to 0 to 5 degrees F.
Could be:
The fresh food thermostat (F21 in Section 5)
The damper (Item 115 in Section 5).
The adaptive defrost board (Item 23 in Section 3).
