The control board on my Maytag Neptune Washer, SN 74990442ZY, lights up when powered, with the start/pause button flashing on and off, and the other buttons set to their correct functions. But the buttons are all frozen; none of them will respond when pressed.
Many thanks for your help!
If you're getting no response at all from any key press, you probably need to replace the touch pad. Part number: AP4026880
