:confused: How hard is it to replace oven igniter on gas stove? THKS.
You have been a member since:: 8/16/2007(UTC) Posts: 3,273
Most oven igniters are hidden under the bottom panel inside the oven. Remove one or two screws to remove the panel, and this exposes the burner and igmiter. Unplug the oven and disconnect the igniter. The replacement igniter should just plug back into the connector.
