I took the dryer completely apart. The drum has a shaft to the rear that sits in a bearing type slot. Should I grease that connection to stop the squealing noise?
Originally Posted by: schrades  I took the dryer completely apart. The drum has a shaft to the rear that sits in a bearing type slot. Should I grease that connection to stop the squealing noise? You might, get by if you put a bunch of Lithium greese where the slot is. Tom ApplianceEducator.com
