Naz Jivraj
#1 Posted : Wednesday, November 5, 2008 5:30:06 PM(UTC)
Naz Jivraj
Condensor motor will not kick in. Tested motor works ok. What could be the possible problem.
Thanks.
Naz:confused:
kayakcrzy
#2 Posted : Thursday, November 6, 2008 4:42:13 AM(UTC)
kayakcrzy
In the back section, where the compressor is, there is a white box, well inside that white box, is a electronic control board. So if you are not getting power to the condenser motor, it is very possible it will be that board. The part # is 2307028 Tom ApplianceEducator.com
alfrednelson
#3 Posted : Friday, September 17, 2010 2:07:56 PM(UTC)
alfrednelson
My 2307028 seems to have gone out as well. Hot between door panels fan has no voltage but runs for a while when power is reset to fridge. Got new control board and put it in but when plugging in it seemed to arc at the plug (thought I blew circuit breaker) but did not, then alarm sounded on board. Could this new board also have a problem. This is for a Whirlpool gc5shexns05 fridge and the appliance parts people assure me this is the correct board.
