dirtyclothes
#1 Posted : Thursday, July 19, 2007 6:53:02 PM(UTC)
dirtyclothes
My Machine wont drain.
The motor will agitate and will spin when enough water is out of it, but wont drain.
The outlet hose will gravity drain so I dont think there is a clog anywhere.
When I fiddle with the controller I can make the pump come on, it hums but doesnt push water.
Is it definitely the pump, or could this still be a controller problem? My controller has some broken plastic and is tough to know what position it is in. I dont want to order a new pump and come to find it was something else? Any ideas?
Dav215PA
#2 Posted : Monday, July 23, 2007 5:02:47 PM(UTC)
Dav215PA
I have the same issue with my Roper washer, Is it the Controller or Pump that needs to be replaced? Can anyone sugest a way to make the determination, please help us, thanks.
DVR
#3 Posted : Monday, August 31, 2009 12:55:41 PM(UTC)
DVR
washer spins slowly but does not drain water during cycle.
GE washing machine wont drain or spin but agitates (Washer Repair)
by Billybrokege 5/14/2015 2:26:58 PM(UTC)
