Baugh
#1 Posted : Wednesday, November 5, 2008 12:45:23 PM(UTC)
Baugh
Hi Guys ,i am in need of help ,my dryer stops after a couple of hours of running ,i change the thermal it worked for 2 hours again ,i change cycle thermostat and the thermal fuse,and check all other fuses and switchs all are good ,any suggeston to help me solve this problem:confused: :confused: :confused:
Drags1998
#2 Posted : Wednesday, November 5, 2008 12:55:58 PM(UTC)
Drags1998
The only thing I can think of is the motor is shutting off on the thermal limit BUILT INTO IT. Make sure thet there is not alot of lint in the motor.:)
