dlynnivie
#1 Posted : Wednesday, November 5, 2008 7:31:27 AM(UTC)
dlynnivie
My washer does not spray water into drum on the final spin leaving soap residue on clothes. The washer fills and drains properly inother cycles. Any thoughts ? thanks
libertyappl
#2 Posted : Wednesday, November 5, 2008 10:25:42 AM(UTC)
libertyappl
Do you wash in cold? If not you may want to remove the hose from the back of the washer and check the screen inside the valve. It could have sediment clogging it.
Nat
Drags1998
#3 Posted : Wednesday, November 5, 2008 1:59:49 PM(UTC)
Drags1998
You have been a member since:: 9/7/2008(UTC)
I know you've heard it before, but use LESS soap, MOST people use to much!!!! 1/2 cap is more than enough. If you have soap left on the cloths after the rinse cycle, Your using to much!!!
