I purchased a Stainless Steel Side by Side Frigidare Refrigerator and for some unknown reason, the water stop working and neither side is getting cold. I changed the filter, no the frig side is cold and the freezer is not. The water and Ice are still not working. Please advise.
Sounds like the freezer fan motor is not running, check it and see. I have one to replace today. When that fan does not run, the water freezes up, so no water will not come out of the dispenser. Because the air is not circulating, and is heavy, so the cold air sits on the bottom. Tom ApplianceEducator.com
