worahm
#1 Posted : Saturday, November 13, 2010 6:35:55 AM(UTC)
worahm
My just over 5 year old GE dishwasher developed a low pitch growling noise that is only present during the wash cycle. Almost like a spray arm is vibrating or hitting something when it spins. The growling noise is not always present. Sometimes, the machine will go through a complete cycle and not make the noise.
I checked to see if the washing arms are hitting anything and found nothing. I have removed the lower spin arm and found nothing unusual.
I can re-create a similar growling noise when I spin the lower arm with my hand. It tends to wobble and does not always spin smoothly.
Other then the low pitched gowling noise, the machine works perfectly.
Read more: http://forum.appliancepartspros...post300959#ixzz15Ay6fkr0
http://forum.appliancepartspros.com
worahm
#2 Posted : Saturday, November 13, 2010 10:10:38 AM(UTC)
worahm
I repaired my noisey GE dishwasher by replacing the missing O ring on the plastic nipple at the rear of the cabinet on the tube that carries water to the middle spray arm. I found the O ring missing. The O ring was approximately 5/8" diameter and fit snugly around the plastic nipple inside the cabinet on the rear wall.
Bill
