Neither the interior light or the two lights above the stove work anymore. I tested all three bulbs for continuity and they all test positive.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Originally Posted by: nauset ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Neither the interior light or the two lights above the stove work anymore. I tested all three bulbs for continuity and they all test positive. Nauset, I'm hoping that you have a bad low voltage transformer, Part number: AP3177761
But in most cases, it usually winds up being the main control board, Part number: AP3130764
Your low voltage transformer(120 VAC in / 20 VAC out) sends the low voltage to the main control board. When you open the door or select the hood light(s) the relay on the main closes and sends the low voltage to the bulb(s). Good Luck, :cool: :cool: :cool:
