I have a Maytag Neptune washer that displays door not locked constantly, I used the tech sheet to run a diagnostic check on the washer. The code I received was 61-Door locked early. When checking the tech sheet for this code it says: Faulty door lock sense switch and Faulty door lock solenoid. I am unable to find either one of these parts, could someone please help me with this? I was told I need a door latch assembly, but did not see these parts with it. Also the serial number is A9355993EG if this helps.
