Our Bosch dishwasher SHX46A05UC/14 is not draining. I have power, when I press the drain button combination the drain pump appears to be working and when I quickly open the door I can see the blue impeller spinning after I had cleanedthe filters and area around the impeller. What else should I check? :confused:
Thanks!
Hello, Very common issue on these units, the drain motor becomes clogged with some debris, if this is the issue you can fix it yourself and here is a video that explains how to do so. If you require further assistance after the watching the video we are here to help you. Bosch Dishwasher Repair Video
