2 Pages<12
sawzalot
#11 Posted : Monday, August 15, 2011 4:38:03 AM(UTC)
sawzalot
Originally Posted by: denman Go to Quoted Post
Should be a 40 amp breaker with number 8 wire.
Here is the install sheet
http://manuals.frigidaire.com/p...assomption/318045091.pdf
You may also want to keep a copy of the wiring diagram.
http://manuals.frigidaire.com/p...assomption/318201661.pdf
Thank You for the response, I was leaning towards the forty amp breaker with an eight / three wire but I was still some what curious as to the specs on the unit and which sized breaker the manafacturer suggested.
Now I have to locate the forty amp range cord and receptacle, not readily available around here, only fifty amp receptacles are in stock every where. Thanks again.
2 Pages<12
