bulletbadcat
#1 Posted : Thursday, November 11, 2010 2:13:32 AM(UTC)
bulletbadcat
My dishwasher will not drain, at all. I have it pulled apart so I can get to :confused: whatever needs repaired/replaced. What do I do now?
magician59
#2 Posted : Thursday, November 11, 2010 7:15:59 AM(UTC)
magician59
First, check the drain hose for kinks or clogs.
Locate the drain pump, which is the first component your drain hose connects to. remove the wires from the terminals, and hook up an extension cord to see if it will run. Be very careful not to let the "test" cord come into contact with anything except the terminals of the pump. If it won't run with your test cord, replace it.
bulletbadcat
#3 Posted : Thursday, November 11, 2010 8:03:23 AM(UTC)
bulletbadcat
Thanks. Is there anyway you could call me. I cannot seem to get this right unless I am "talking" to someone.
Charlotte 937-737-0093
THANKS!!!!
magician59
#4 Posted : Thursday, November 11, 2010 9:06:07 AM(UTC)
magician59
I am busy at work right now (Locksmith dispatcher). If you're able to wait until after Five o'Clock central time, I'll call you after I close the shop.
