jjm
#1 Posted : Tuesday, November 9, 2010 4:07:51 PM(UTC)
jjm
When you set the dryer cycle you want it will dry the clothes but will not shut off it will go into the next cycle.
#2 Posted : Wednesday, November 10, 2010 1:13:17 AM(UTC)
Groups ready for retrieval: Senior Expert
Replacement parts for lnc7766a71 models | AppliancePartsPros.com
I do not have a wiring diagram for the unit so the below is a bit of a guess.
It sounds like a timer problem.
I am assuming the timer rotates past off to the next cycle.
Unplug the nit and open up the console.
The timer should have connections marked L and M.
L is power in (L1).
M is for the motor.
Remove the wire going to one of these. This prevents you from reading an alternate/parallel circuit path.
Now measure across the 2 connections.
When in a cycle, they should read 0 ohms (closed).
When at off,they should read infinity (open).
If they do not open then the timer is toast, the contacts are welded together.
Note: You may find the wiring diagram in the console, it is a favorite storage area for many manufacturers.
gas dryer wont shut off on sensor mode (Dryer Repair)
by m218perez 6/20/2014 7:26:43 AM(UTC)
estate dryer wont shut off (Dryer Repair)
by centerville1966 2/15/2014 1:39:29 PM(UTC)
Maytag dryer wont shut off after cycle (Dryer Repair)
by knzvet 11/3/2013 4:00:37 PM(UTC)
My dryer wont shut off on its own (Dryer Repair)
by tracy0821 12/23/2012 8:20:20 PM(UTC)
Maytag Dryer Wont Shut Off (Dryer Repair)
by mikeb104 4/7/2012 11:17:29 AM(UTC)
by craig97ss 10/1/2011 8:34:29 AM(UTC)
Dryer wont shut off when I open the door (Dryer Repair)
by Chad The Handyman 4/19/2011 6:14:58 AM(UTC)
dryer wont shut off by itself (Dryer Repair)
by bremark 3/4/2011 11:44:25 AM(UTC)
Gas Dryer Wont Shut off Automatically (Dryer Repair)
by garytk 10/9/2009 1:22:18 PM(UTC)
by sgerry 7/14/2008 8:46:31 PM(UTC)
