pgc
#1 Posted : Monday, November 8, 2010 6:52:11 PM(UTC)
pgc
Freezer was very cold, ice build up in ice cube container area.
condensor fan was not working....replaced condensor motor and fan.
Still freezer was very cold, ice continued to build up...replaced freezer temperature control. Was ok for several hours...refrig and freezer recycled, freezer was cold, refrig was ok/cold...water dispensor did not dispense water...freezer and refrig are now very cold again. Now both refrig and freezer very cold (both areas are so cold even at lowest setting of 1 that both areas freeze water). What should I do? Replace fresh food temperature control? what should I do regarding ?:confused: :mad:
#2 Posted : Tuesday, November 9, 2010 1:35:48 AM(UTC)
Replacement parts for FRIGIDAIRE PLHS267ZDB2 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389618.pdf
And a manual
http://frigidaireservicetips.com/pdfs/495_2.pdf
Since you have already replaced the freezer thermostat I would say that the adaptive defrost board is the problem.
It is all that is left in the compressor control circuit.
