mr fix it
#1 Posted : Monday, November 8, 2010 7:26:58 AM(UTC)
mr fix it
The Idler pully mounting bracket is secured with a shoulder bolt.Question is there a fair amount of play or slop in this assembly.I am trying to determine if I need a new mounting bracket.
Thank you
magician59
#2 Posted : Monday, November 8, 2010 8:36:49 AM(UTC)
magician59
As long as the return spring is good and you're using the proper belt, a little side play on the pulley bracket is normal.
