No voltage to upper oven broiler, no fault codes, replaced upper sensor, all other features work. It this the limit switch thermostat or (GASP!) the ECM? Element upper oven broil tested OK, but when on broil, there is no voltage to that element.
THIS FORUM IS DEAD!!!!!!! |
