helpkenmore side by side not cooling or freezing could it be defrost heater & timer or start device relay also ice is sticking on bk of freezer:(
Sounds like a major defrost problem. remove the rear panel in the freezer and check for ice there. you will want to check the defrsot timer, heater & thermostat.
Nat
