Kenmore top loader won't agitate. It fills with water and then does nothing. The washer is about 1 1/2 years old and only been used less than 50 times. Help!
Groups: Expert
Originally Posted by: kafitz  Kenmore top loader won't agitate. It fills with water and then does nothing. The washer is about 1 1/2 years old and only been used less than 50 times. Help! It could be your lid switch. I'd start there. If its working OK, then it could be the pressure switch or the motor or the timer.
