Standing pilot on oven works ok. When oven turned on safety pilot lights but burner flame stays low. Tapping the valve restores full burner flame but is not a fix it happens again when turned off then on. It is sticking/dirt in valve? Any fix available? What are part numbers for getting a new valve and new thermocouple? Thanks!
The only solution is to replace the gas safety valve. Such parts are not serviceable. This model is very old and there are no on line diagrams available. You have to talk to the Appliance Parts Pros team to find out the correct part number as well as the price and availability. You can use the Live Chat or call them 877-477-7278. Gene.
