chuck clark
#1 Posted : Thursday, November 4, 2010 9:40:32 AM(UTC)
chuck clark
My daughters GE dishwasher makes a vibrating sound when it is turned on. I tcontinues for about 5 min then goes away (coincident with opening of detergent door).
If the door is opened when it is making the sound, water will be in bottom but none apparently on dishes. After noise stops and door is opened, then dishes will be wet.
It will clean OK but only if not packed as full before vibrating started.
Thanks for your help,
Chuck Clark
#2 Posted : Thursday, November 4, 2010 1:16:23 PM(UTC)
Chuck,
Make sure that this vibrating sound is not coming from the dishwasher water shut off valve.
Open the dishwasher door during the wash cycle and check the water level inside the dishwasher. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSD1200X01 Dishwasher | AppliancePartsPros.com
chuck clark
#3 Posted : Thursday, November 4, 2010 3:07:50 PM(UTC)
chuck clark
Thanks Gene. I will get back to you tomorrow, most likely.
chuck clark
#4 Posted : Saturday, November 6, 2010 11:13:53 AM(UTC)
chuck clark
My daughter called this afternoon and said the water level a couple of minutes after the sap dispenser opened was about 2" at the center and at various other points. She also said it did not vibrate in that period before the soap dispensor opened, which is usually does.
Thanks,
Chuck Clark
#5 Posted : Monday, November 8, 2010 4:40:20 PM(UTC)
It is very hard to say what is wrong with this dishwasher without seeing it. Unfortunately not everything can be diagnosed and fixed remotely. Your daughter probable has to call a pro.
