jmo9556
#1 Posted : Wednesday, November 3, 2010 5:49:58 PM(UTC)
jmo9556
Got a strange one. My Whirlpool electric range will not fire up the broiler element. I've replaced the element and the thermal fuse. Still nothing. I did a check from the panel and it shows "good" I hear a click from the left side of the panel, looking from the front, and still nothing. My manuals tell me nothing. So, I guess my question is, what am I missing? Is the panel fried? Everything else works great. The broiler just stopped one day.
Jon
kayakcrzy
#2 Posted : Thursday, November 4, 2010 3:50:54 AM(UTC)
kayakcrzy
Jon
Jon, just because you hear that click at the clock control, does not mean that it is functioning properly. It is most likely the clock control, since you replace the broiler element. If you want to know for sure. Unplug the stove, and take the 2 wires off of the broiler element, and if you have a volt meter, put one lead on one wire, and the other meter lead on the other wire terminal, and then plug it in, and ask for broil. You should get a 120 volt reading. If not, replace the clock control. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
#3 Posted : Thursday, November 4, 2010 6:02:35 AM(UTC)
I think kayakcrzy had a typo. You should see 240 volts across the element.
Here is the manual which you may already have.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/5feedbe46138625985256aa1005ef62c/$FILE/8178042.pdf
First thing I would do is pull the thermal fuse and check it with a meter to be sure it is 0 ohms. Would not be the first time a part was bad right out of the box. Might not be a bad idea to also check the element, approximately 18 ohms.
It is always a good idea to check parts before installing them, can save you ripping a unit apart twice or going in circles trying to repair a machine because you assume that the new part is good.
