neyeseeu
#1 Posted : Wednesday, November 3, 2010 12:51:47 PM(UTC)
neyeseeu
Please Help me!!, All fans are working, Relay on compressor keeps clicking on and off every minute to 2 minutes, all coils are cleaned and no frost anywhere both freezer and frigerator are Dry. Thank you if you could take the time to help
applianceman
#2 Posted : Wednesday, November 3, 2010 2:11:25 PM(UTC)
applianceman
The problem is either the compressor or the relay. The best way to tell for sure is to replace the relay and if it works fine and if not the compressor is bad. This is assuming that coils on the outside are clean (not clogged with lint). This can cause the compressor to overheat although this will typically take longer than 2 minutes so I believe the problem is in the start relay or compressor but check it anyway.
Refrigerator repair guide
#3 Posted : Wednesday, November 3, 2010 2:32:00 PM(UTC)
You can find the instructions on how to check the compressor in one of our previous threads: http://forum.appliancepartspros...s-but-does-not-cool.html
The compressor start relay and overload are shown as #13 on the diagram.
- The start relay and overload kit Part number: AP3083556
neyeseeu
#4 Posted : Thursday, November 4, 2010 6:57:14 PM(UTC)
neyeseeu
Hello Applianceman, Gene,
Thank you for your direction in this matter.
I will follow them exactly and will keep the both of you posted
Again Thanks,neyeseeu
neyeseeu@yahoo.com
